weber install help me
turbeau
im in la mesa, which is part of san diego. i am converting from SUs to triple webers on my 71 240z. I have zero experience with this set up and am running into a few problems. What I need is an experienced Z guy to come see if I set it up okay. 619-578-8583 my name is Beau, thank you very much
well i have a couple specific questions with pictures ( hopfully they work)
1. my stock 71 linkage is 2 1/2 inches too long to fit on the linkage for the webers, what do people do?
2. all of my webers are missing this plate on the back, the choke plate? can i run without it and will it affect driveability? beyond just starting it up and waiting?
3. where should i plug in the tube for the (vacuum advance?) from the bottem of the distributor?
4. what about a heat sheild, custom?
5. as it is now there is no fuel return, both sides are plugged. is this okay?
6. the SUs had a coolant line going through them, the webers dont. is this okay?
thanks for any and all the help
1. Cut and weld
2. YES...you need that, or the blockoff plate...they are out there
3. CANT...take it off the dizzy and throw it away
4. Kamineri sells the "Datsun Comp" heat shield (some mods required for use with webers but bolt on for Mikunis) or custom
5. I recommend using the factory SU fuel rail
6. no coolant line required
You will need to take the carbs off the manifold to install the blockoff plate. I reccomend How to Build & Power Tune Weber & Dellorto DCOE & DHLA Carburettors My link
1. find a different size linkage (mine worked fine and i have a 72
2. dont need it since we live in southern california, never ran with em and never had an issue
3. no vac advance, set it a bit higher than normal. i ran 15-18deg advance on a e12-80 ran like a champ
4. custom make a heat shield if you really want one, i never had one and it never was an issue.
5. i never ran a fuel return, but if you want one you can do a search there is a diagram out there that describes the best way to have it with a FPR
6. dont need a coolant line, it is worthless in southern california.
cool thanks guys,i just got it all installed and started it up.
Zach, the return springs you used seem very strong and offer too much resistance while revving. I will probably switch to softer springs.
at about 4k rpm it was backfiring out the carbs
smelling very "fuely" running rich, rather rich than lean
how high can these rev, and how should i rev them safely?
tomorrow i will drive it around the block and see what it feels like, im so excited
Low fuel pressure is most likely not what's causing your problem... That's my point of view.
It would be helpful to start by knowing the jets sizes (idle jet, main jet, air jet, emulsion tube & choke size) you have in your carbs, check as well the float level - make sure it is the same for all of the carbs.
Backfire could also be due to bad timing. I would check timing & distributor with a timing light as well.
