Phenomenon Posted September 5, 2010 Share Posted September 5, 2010 Finally got my 350 / 700r4 swapped into my 81 280zx and it runs great. Tach is all hooked up and working too. What are you guys doing to run the factory speedo with the 700r4 trans that has the elctronic output? I thought about going with an aftermarket gauge but with the circuit board on the back of this cluster it won't work without rewiring a ton of stuff. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 5, 2010 Share Posted September 5, 2010 Its a little expensive but there is a converter called cabel X. Quote Link to comment Share on other sites More sharing options...
kj280z Posted September 5, 2010 Share Posted September 5, 2010 I have a cable x for sale if you're interested pm me Quote Link to comment Share on other sites More sharing options...
FrankinZ Posted September 14, 2010 Share Posted September 14, 2010 You can run the electronic system if you want. A cheaper way out is to install a speedo gear assy. from a turbo 350 and adapt it to your existing cable. Just need to use the correct size gear. The cable adaptor is available from MSA. Any transmission shop can hook you up with the right gear combo. Quote Link to comment Share on other sites More sharing options...
Phenomenon Posted September 14, 2010 Author Share Posted September 14, 2010 Problem is then i have to tear the trans apart as it has the electronic gear not the tooth gera for driving an output. For now i'll just stick with my GPS as a speedo...lol Quote Link to comment Share on other sites More sharing options...
