ModernS30 Posted September 10, 2010 Share Posted September 10, 2010 Hey guys, I recently 'let the smoke out' of the ignition resistor on my 240z trying to get it running. It started, it has a full 1977 280z EFI, ignition, and body harness. All the wiring is from the 280z. I had the car running and then when I finished running my fuel system I tried to start it. To my avail there goes the ignition resistor, smoking! Well, I pulled it off, I was just going to buy one from somebody, but it should be a simple fix, just buy the proper ohm resistors and screw them down like factory. Basically I am wondering what ohms these resistors are, or maybe somebody knows where I can find out. I figure it will allow me to go a little more modern compared to from the 70's as well as keeping cost very low, resistors are pretty cheap from radio shack or anywhere really so it should only be a couple dollar fix. Any help is greatly appreciated as I couldn't find squat when I searched. Maybe this could help somebody else in the future? Thanks a bunch Kinser Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted September 10, 2010 Author Share Posted September 10, 2010 (edited) Ok guys, it seems like super low so I must be wrong on something. In the FSM for a 77 there is a little chart. It says: External resistor at 20C (68F) Ohm..............................1.15 to 1.45 (Standard resistor 0.4 + 0.9) Now, what I was getting from this, is that the little coil was a 0.4 ohm resistor, and the larger one was a 0.9 ohm resistor. The problem I am having is, there is for sure not any resistor that small I can find. Maybe somebody can point out what I am doing wrong here? I must be looking at something wrong. I will try to scan the page or something. It is on page EE-39 if the 280z Datsun FSM. Now, if the resistor is that small, does anybody know where I can get one? EDIT: Also, maybe somebody knows what Watt the resistor is supposed to be? Boy is this getting to be more difficult than it should. If I can figure these things out then I will just do it myself. I would much rather replace it with modern items than the same old used one that is just going to quit on me again. Thanks again, Kinser Edited September 10, 2010 by ModernS30 Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted September 10, 2010 Author Share Posted September 10, 2010 Ok, I still do not know the ohms, but it seems if I use a more modern coil then I should be able to just bypass the resistor, it is actually called the ballast resistor. Kinser Quote Link to comment Share on other sites More sharing options...
