Can You Race With An Automatic Transmission?
vijay12
First of all, yes its "possible". It won't stop you from physically being able to attend track events. As long as your transmission is in good shape and you do regular fluid changes and no nuetrel drops, it shouldn't mechanically be a problem. Is it desirable, not for road racing and simple drag racing. However, alot of the extremely high horsepower, drag racing built cars have some sort of form of an automatic.
Second of all, you bought a Del Sol, I don't think you'll be "racing" much of anything.
Edited by LoneStarS30Z
my first 240z track car was an automatic, at the same time 4 other zed's on the local track were auto's also so that was 30% of the zed that were active at the track (mid 90's). All were factory 3 speed items with high stall torque converters. You could run with most of the manual zed but the lack of ratio section let it down on the fast straights and this is were the manual either got away or would catch up (for a bit at least)
It did teach you how to corner and brake correctly as the ratio issue meant to stay in front of other cars you had to get it right.
