dpuma8 Posted September 18, 2010 Share Posted September 18, 2010 I just recently bought this car from Voltron_Boi and I am pretty excited http://forums.hybridz.org/index.php/topic/94348-1975-280z-with-l28et-swap/ I have a few questions since I can't seem to find concrete enough answers by doing a search. 1) The car comes with the act extreme 6 puck disc and pressure plate. When I shift through the gears, it is pretty rough through the gears like it slams into gear and then takes off. IS this normal with a performance clutch? I haven't had a car with an upgraded clutch before. 2) It is hard to shift into gears. It will grind sometimes but just overall is hard to get in there. Voltron said to bleed the tranny and it will be fine. Is there anything else I should look out for? 3) The car is missing door locks and I see that each lock is surprisingly $135+ (I thought it would be like $20). Does the lock have to be 280Z specific or can a locksmith put some universal lock in for much cheaper that will work with my ignition key? If it is possible, how much should I expect to pay? 4) The brakes push all the way to the floor and then the brake is really touchy. If the brakes work well but the pedal goes to the floor, is there something wrong with it or need to be fixed? 5) The car sits really low and rubs the fenders. You can turn the steering wheel 90 degrees and then the front rubs on the fender. The springs are cut so I would like to do some coilovers or some combo that allows me to adjust ride height. I haven't seen any posts for coilovers so doesthat mean there aren't any direct bolt ons? Quote Link to comment Share on other sites More sharing options...
dpuma8 Posted September 18, 2010 Author Share Posted September 18, 2010 6) Looks like the seller didn't tell me that the battery goes dead until he left. He said that at night, the battery needs to be unplugged. What could be the problem? Quote Link to comment Share on other sites More sharing options...
78_S30_L28 Posted September 18, 2010 Share Posted September 18, 2010 4) The brakes push all the way to the floor and then the brake is really touchy. If the brakes work well but the pedal goes to the floor, is there something wrong with it or need to be fixed? try bleeding your brakes, i would guess you have air in your lines Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 18, 2010 Share Posted September 18, 2010 Check the reaction disk sticky, bleed the clutch hydraulics, find the drain in the electrical system, which door locks are you talking about? if it's the outside ones, just go to the junkyard. Quote Link to comment Share on other sites More sharing options...
