280zxt fuel pump wire(pin 37)
zzRaVeNzz
Hey guys I have a 1982 280zxt just installed megasquirt and I need to know how to wire up the purple wire from the painless harness from diyautotune.com. I know i need to wire it up to the fuel pump relay but not sure which wires, i'm using ms2 extra 2.1 by the way.
thanks
  • 1 month later...
I'm built my own relay board. The fuel pump wire off the ecu connects to the ground contact on the relay. The ecu engages the switch and grounds it if the system is getting rpm or not.
You should have received a wiring diagram with diyautune package.
