slimpac Posted September 30, 2010 Share Posted September 30, 2010 Hi i recently got a 82 280zx, and it has a new fuel pump, engine rebuild and other small things, but it has one electrical problem (what the previous owner said) that when it starts up it turn off by itself. The battery in it isn't very good though, if that is an indicator about anything. Thats the only thing wrong with it (i think) but i really want to get this baby running! please help me!! Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted September 30, 2010 Share Posted September 30, 2010 Most fuel injected cars won't run without a good battery and a good charge, They are pretty specific about the voltage going to the ECU for it to run correctly. Replace the battery and that should fix your problem. Does your car stumble and you have to hold the gas to keep it running, what are some of the cars symptoms? Quote Link to comment Share on other sites More sharing options...
slimpac Posted September 30, 2010 Author Share Posted September 30, 2010 It just turns on for a second or two then dies by itself, no stumbling, but i'm going to put a new battery in it and see if it runs first thing tomorrow morning, i'll let u know how that goes. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted October 1, 2010 Share Posted October 1, 2010 (edited) Be sure your battery cable terminals are tight and free of corrosion. just putting in a new battery with crappy cables may not solve your problem. be sure the ground goes to the frame and then to the starter. grounding thru the starter is not a reliable connection. it should go to a bolt about a foot below the battery. Edited October 1, 2010 by roger.svoboda Quote Link to comment Share on other sites More sharing options...
wagon jon Posted October 14, 2010 Share Posted October 14, 2010 Make sure you check your alternator. That could cause some of the symptoms your car possesses. Quote Link to comment Share on other sites More sharing options...
