Which z has a 20mm front sway bar
Guest ttoude
Guest ttoude
Which z has a 20mm front sway bar? OR what where the stock diamiters for 240, 260 & 280?
The swaybar on my 77 is currently 18mm, this is relevant cause my energy bushing master set offers the sway bar bushings as an "option" cause of the three different possible diameters. So I might as well get a 20mm bar, if I can find one. Thx
:::::::::I searched and found some good info most pertaining to the rear swaybar and one guy that was going to heat, reshape and possibly re-section a spring steel sway bar:::::::
