yem73z Posted November 9, 2010 Share Posted November 9, 2010 Im doing the vq swap in my 73z, and was wondering if austins shifter relocation bracket will work with an ebay short shifter. Quote Link to comment Share on other sites More sharing options...
cockerstar Posted November 9, 2010 Share Posted November 9, 2010 IIRC, it should. Read through his thread on it and look at how the relocater is designed. I know of at least one member running a short shifter with his kit, but I don't recall the brand. Quote Link to comment Share on other sites More sharing options...
yem73z Posted November 9, 2010 Author Share Posted November 9, 2010 I was wondering if everyone doing the vq swap using drive by wire or is it easier to use a throttle cable in conjunction with the q45 throttle body. Quote Link to comment Share on other sites More sharing options...
Jared Posted November 9, 2010 Share Posted November 9, 2010 No reason why it wouldn't work with a short shifter, it's designed to accept all stock components. You'll need to keep the drive by wire if you're using the stock ECM. If you're running a standalone, then go with a cable operated throttle. Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted November 9, 2010 Share Posted November 9, 2010 yeah that bracket is nice, I bought one. It'll fit any aftermarket 350z shifter since it duplicates the stock shifter mount. though modifying the connecting rod between the shifter and the tranny is required. (easy welding job) Quote Link to comment Share on other sites More sharing options...
yem73z Posted November 10, 2010 Author Share Posted November 10, 2010 Thanks for the advice guys, i'll be sure to update my progress Quote Link to comment Share on other sites More sharing options...
