Help with what unused brackets to remove from engine bay
Scott_M67
I thought I would ping you guys to see what brackets would be good to remove from the engine bay of a '77 that is getting a L28et and Z31 MAF install. I'm thinking I should remove any brackets for the aircleaner and the AFM and clean that area up, can you guys think of any others that aren't used in the swap?
Thanks.
This is a picture of the engine bay in our '77 project, since the car will be getting a l28ET and the Z31 ECU and MAF I thought it would be good to remove any brackets that are not needed. Does anyone see any reason to keep the AFM mount stuff?
Thanks for the input.
After all was said and done, I wish we had removed those from my son's '76 280 while we had the original engine out... They just got in the way with a stock L28ET swap. If you have any cold-air or charge piping in mind, it'll probably be a lot easier with those gone. You're never going back to an L28E AFM, are you? Didn't think so...
