ridin_Z_alb Posted November 23, 2010 Share Posted November 23, 2010 (edited) So I bought a ms1 v3.0 from a member on here about a year ago and i finally got around to hooking it up a couple months back. Now the problem, Everything seems ok when the controller is hooked up to jimstim.(pin 36 jumped ign light number 1,set for hall sensor.) I have the whole setup wired according to msextra and diyautotune to drive a signal coil off a nissan optical dizzy. megatune (along with tunerstudios) is reading engine speed(rpms) just fine i have 256 rpms during cranking which seems about right. I am running a completely stock l28et and of coarse a relay board pre-assembled from diyautotune its a 83 turbo motor once again, its wired just like diyautotune describes. I am at a loss here and have no idea what to try. as soon as I can figure out how to export my tune on here i will. please guys I'm all outta ideas. Ive used the search button, Ive read the manuals I guess if its there my reading comprehension skills suck. (but what do you really expect out of a nineteen year old?) Edited November 24, 2010 by ridin_Z_alb Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 30, 2010 Share Posted November 30, 2010 Is it using a VB921 or a BIP373 for spark output? Quote Link to comment Share on other sites More sharing options...
ridin_Z_alb Posted December 4, 2010 Author Share Posted December 4, 2010 vb921 Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted December 7, 2010 Share Posted December 7, 2010 The VB921s had a pretty high failure rate. You may need to replace it. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted December 14, 2010 Share Posted December 14, 2010 (edited) I had this issue and i had to replace my vb921. If you search my name, you'll find a thread with pictures of my melted component. Definitely start there, you'll thank yourself later. Beyond that, make sure your coil wiring is correct and test that you have power there. Edited December 14, 2010 by jacob80 Quote Link to comment Share on other sites More sharing options...
ridin_Z_alb Posted December 19, 2010 Author Share Posted December 19, 2010 found the relay board to be bad apparently I overlooked it. thanks for all the help guys. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 20, 2010 Share Posted December 20, 2010 What was bad with the relay board? It might help other people to hear the details. Quote Link to comment Share on other sites More sharing options...
