ritrebor Posted November 28, 2010 Share Posted November 28, 2010 What do these 2 wires connect to? 77 280z attached to the ignition switch. Thanks in advance. ritrebor Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted November 28, 2010 Share Posted November 28, 2010 (edited) http://www.xenons30.com/reference.html They have the 77 FSM, Just look at the wiring diagram. Or you could use this. http://www.atlanticz.ca/zclub/techtips/wiringdiagrams/F77ZCAR-WIRING1.pdf PS: It goes to the ignition relay. Edited November 28, 2010 by 19762802+2 Quote Link to comment Share on other sites More sharing options...
ritrebor Posted November 30, 2010 Author Share Posted November 30, 2010 Steering lock switch? ritrebor Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted November 30, 2010 Share Posted November 30, 2010 Steering lock switch? ritrebor No, The steering lock switch isn't Electrical its Mechanical, When you put the key in the lock position it releases a small metal block and when you turn the steering wheel into the right position the metal block slides into the steering column. When you turn the key from the lock position it slides the metal block back out and un locks your steering wheel. Quote Link to comment Share on other sites More sharing options...
ritrebor Posted November 30, 2010 Author Share Posted November 30, 2010 ON the AtlanticZ wiring diagram it shows an Steering lock switch that is connected to a relay. 2 wires coming out of it. Right above the combination switch diagram. Was thinking it also could be a key warning switch but couldn't find it on the diagram.?? 3chev Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted November 30, 2010 Share Posted November 30, 2010 (edited) ON the AtlanticZ wiring diagram it shows an Steering lock switch that is connected to a relay. 2 wires coming out of it. Right above the combination switch diagram. Was thinking it also could be a key warning switch but couldn't find it on the diagram.?? 3chev Sorry, I didn't notice that. I guess the later Z's were a bit different, I traced the diagram and it looks like the ground for the steering lock switch goes to the Door switch then to the ground and and it runs into a power line from the Hazard lights relay. So the steering lock switch is activated or turned off when the door is closed or opened. I would guess that the Steering lock switch just looks like a small relay under the dash. I think those wires go to the ignition relay. The only blue and red wire coming from the Ignition in the diagram goes to the Ignition relay. Edited November 30, 2010 by 19762802+2 Quote Link to comment Share on other sites More sharing options...
bjhines Posted December 9, 2010 Share Posted December 9, 2010 I remember the buzzer when you open the doors with the key in... or was that my 1970s Toyota. Quote Link to comment Share on other sites More sharing options...
