Tee Posted November 28, 2010 Share Posted November 28, 2010 Hi guys, after posting up my vid on here and seeking advise from elsewhere, figured that the clicking sound from engine that increased with rpm was down to leak from exhaust manifold, so changed the gasket and studs but noise is still there. So now I've been told it could be a crack in the manifold. This may sound stupid but for this do I just need to replace the exhaust manifold or are any other parts required? Also I've seen a 6 branch manifold locally, what are the advantages of this over the standard 280zx exhaust manifold? Quote Link to comment Share on other sites More sharing options...
FricFrac Posted November 29, 2010 Share Posted November 29, 2010 Hi guys, after posting up my vid on here and seeking advise from elsewhere, figured that the clicking sound from engine that increased with rpm was down to leak from exhaust manifold, so changed the gasket and studs but noise is still there. So now I've been told it could be a crack in the manifold. This may sound stupid but for this do I just need to replace the exhaust manifold or are any other parts required? Also I've seen a 6 branch manifold locally, what are the advantages of this over the standard 280zx exhaust manifold? You can still have a leak from the exhaust manifold even if you replace the studs and the gasket if the manifold itself is warped (which does happen). I'm not sure what you mean by a 6 branch manifold. If you are talking about a header then the advantage would be better exhaust flow which helps the engine to breath better giving it more power and better fuel economy. Quote Link to comment Share on other sites More sharing options...
ovenfood Posted November 29, 2010 Share Posted November 29, 2010 although the standard is pretty good, i upgraded to lukey's and didnt notice anything :/ lucky they were free :> Quote Link to comment Share on other sites More sharing options...
