Matt K Posted December 3, 2010 Share Posted December 3, 2010 I've done some searching, but just want to confirm that in order to use this short nose R200 LSD (R32 GTST Nismo CLSD, not VLSD) in my '78 280Z with longnose R200, I only require the spacers for the 12 to 10mm bolts My link? Everything else is good to go, since the '78 is an original R200 car, right? Nothing else needs to be swapped or modified, so long as I'm only installing the diff itself? This is new to me, so please don't flame me too bad...I just want to be prepared. Thanks! Quote Link to comment Share on other sites More sharing options...
cockerstar Posted December 3, 2010 Share Posted December 3, 2010 Do some searching on spline counts. Quote Link to comment Share on other sites More sharing options...
Matt K Posted December 3, 2010 Author Share Posted December 3, 2010 So the 280Z has 27 spline stub shafts...and most of the short nose R200 LSDs are 29? So basically, I'd need Z31 Turbo stub shafts (& adapters?)...ugh! Quote Link to comment Share on other sites More sharing options...
MAG58 Posted December 6, 2010 Share Posted December 6, 2010 So the 280Z has 27 spline stub shafts...and most of the short nose R200 LSDs are 29? So basically, I'd need Z31 Turbo stub shafts (& adapters?)...ugh! Huh? Stub shafts don't really matter with what diff you're putting in it (you need the right output companion flanges for it, but they have no bearing on what diff you have in it). All of our R200 long nose, save for the R200V out of the 88SS are 29 spline. The R32, most S1x chassis cars, the Q-ship, the Z32, and most other short nose R200's are 30 spline. .... If only this was in a sticky somewhere.... Quote Link to comment Share on other sites More sharing options...
