stock rb26dett air fuel ratio?
ktown z
So my car is finally running with the rb26dett in it. I am running a bosche 044 fuel pump with stock lines, fuel rails, injectors, ecu, MAFs and fpr. While I'm under boost of just 9lbs my A/F ratio is lean around 14.7. I believe this is not safe and should be around mid 12's. Does anyone know what the stock A/F ratio of the RB26 and why its running lean? The only other mod that can change the A/F is the custom twin intakes.
any exhaust leak within close proximity in the exhaust stream can cause a leaner than actual reading. Also How about a full list of mods. Are you sure the injectors are the 26, and not 20,25? Was the 14.7 when you were under a load (actually seeing 9 psi) or just while idleing, or cruising? Idle and cruise would be lean, only time to richen is under load.... Ah both afm's hooked up properly? hmmmmmmm
well with stock ecu and stock rb26dett, my a/f was in the mid 10"s to high 10's. this was with a motec wb.
