michaelp Posted December 5, 2010 Share Posted December 5, 2010 (edited) Current "Spec": 9:1 Compression A/B Series VG30ET Polished LIM Turbo 260cc Injectors Nistune with stock European Tune atm Walbro 255LPH 3" Turbo-back exhaust, mandrel bent /w no cat Z3R Springs, 300lb/in front, 315lb/in rear DXD Stage 2 clutch Custom FMIC setup with 2.5" piping Manual Boost Controller @ 11psi Intrepid Electric Fans Custom turbo inlet /w 3" K&N cone filter Conquest Wheels CHANGED MY POWER GOALS TODAY! To come: 8.9:1 Compression VG33E - owned Ported/Polished Upper and Lower intake manifolds - owned Ported OWO Heads (VG33 heads) - owned Z31 euro cams, or custom grinds 450cc Injectors (DSM) - owned Custom Tubular Twin Turbo Manifolds - owned Upgraded stock T3 3" turboback mandrel bent - owned DXD Stage 4 Multi-core radiator New FMIC setup CLSD Z32 Brakes uh..i had a bigger list at one point, i'll update later when I remember it all. VG30ET (9:1 CR - blown headgasket now due to overheating) VG33: Edited December 6, 2010 by michaelp Quote Link to comment Share on other sites More sharing options...
hoov100 Posted December 5, 2010 Share Posted December 5, 2010 I would highly recommend cleaning out the casting flash in the coolant passages on the vg33 if the motor is out, or the heads are off, also aren't two t3's a little laggy for for a 3.3L? Quote Link to comment Share on other sites More sharing options...
michaelp Posted December 5, 2010 Author Share Posted December 5, 2010 Yupp, I'll be doing some work with all that. Not really sure, I'm expecting full boost no later than 3500rpm, but it may not work out how I plan. If it doesn't, I'll find some different turbos with a different turbine side but similar compressors for better spool, but it should support nearly 500whp. Quote Link to comment Share on other sites More sharing options...
michaelp Posted December 6, 2010 Author Share Posted December 6, 2010 So, today I decided to change my power goals. I have no use for 400-500whp, drag racing isnt my thing. I'm into auto-x and drifting, or just simply playing in the twisties...decided to shoot for around 300whp with a single upgraded T3, then focus on suspension. Quote Link to comment Share on other sites More sharing options...
