Z31TURBODRAY Posted December 14, 2010 Share Posted December 14, 2010 I will most likely be doin the rb25 swap unless I can find somethin cheaper,mckinney makes the mount kit but it really cant be that easy right? is it just a direct bolt on kit and I can have my motor and tranny bolted up no problem? or do the mounts just make it easier and less custom work? am I still gonna have to do a few mods for it to fit perfectly? if thats the case then ill just have the mounts done at a shop and maybe it would be cheaper than mckinney? thanks guys Quote Link to comment Share on other sites More sharing options...
jakeoster Posted December 14, 2010 Share Posted December 14, 2010 This has been covered many many times.... Search dude. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted December 14, 2010 Share Posted December 14, 2010 I will most likely be doin the rb25 swap unless I can find somethin cheaper,mckinney makes the mount kit but it really cant be that easy right? is it just a direct bolt on kit and I can have my motor and tranny bolted up no problem? or do the mounts just make it easier and less custom work? am I still gonna have to do a few mods for it to fit perfectly? if thats the case then ill just have the mounts done at a shop and maybe it would be cheaper than mckinney? thanks guys There are a lot of critical angles that need to be considered when you stuff a powertrain into a car. If you are not sure "how easy it is", then it probably is not. Buy from someone who already has it figured out. It is still not that simple, however. Likewise, the SR swap is cheaper than the RB swap. Keep reading and learning before you pull the trigger. Quote Link to comment Share on other sites More sharing options...
Z31TURBODRAY Posted December 14, 2010 Author Share Posted December 14, 2010 well the reason im so ready and confident to do this swap is cuz ive done many swaps in the past just never a swap that is completely not made for the car like this lol Quote Link to comment Share on other sites More sharing options...
jakeoster Posted December 14, 2010 Share Posted December 14, 2010 (edited) Maybe go with an L28et? That's more or less "made for the car" and is considerably cheaper. You'll see some good gains as well. As for the RB this forum has all the info you need, please search before posting though as this is a very standard question. Not trying to be a jerk or nuthin as we all started somewhere, but your posts so far seem to indicate that your not as confident in your abilities as you should be when undertaking such a project. Like a few others have said, give it some thought before diving in. Edited December 14, 2010 by jakeoster Quote Link to comment Share on other sites More sharing options...
