ZT-R Posted December 30, 2010 Share Posted December 30, 2010 Hey guys, i have a 11mm fuel rail and i would like to get this think cranked up on the stock injectors for right now. can i just use a thicker o-ring on the stock (10.5mm) injectors? or will this just blow out... Quote Link to comment Share on other sites More sharing options...
jakeoster Posted January 1, 2011 Share Posted January 1, 2011 Now this is my guess, someone else chime in if Im wrong... High pressure needs a good seal. I would imagine that if it doesnt match up all the way then you will most likely run into problems. Quote Link to comment Share on other sites More sharing options...
RS Speed Posted January 2, 2011 Share Posted January 2, 2011 My friend used that combo with these big o-rings which were supplied with the fuel rail and although I was skeptical they worked out fine. I believe they were greddy injectors on a JGY rail. Quote Link to comment Share on other sites More sharing options...
