Car Stalls Under Hard Acceleration
Hello everyone,
I recently purchased another 240z with an unusual engine combination and have discovered an issue that causes the car to stall under fairly hard acceleration (4-5k rpm). AS soon as I let off the throttle it ALMOST ALWAYS STALLS unless I blip the throttle and shift gears quickly. Sometimes I can start the car up after it stalls but occasionally it wont start up because it will not spark anymore UNLESS I unplug a connector to the ignitor and reconnect it.
I was told by a mechanic that it can be that I have a NON-FI fuel tank and I need a larger return line (75-76 280z fuel tank), and that my fuel pressure is really high (around 70). I would appreciate if anyone has any advice or has had a very similar issue.
One last and final thing. My car does not have a TPS because it has a 240sx throttle body, should I remove that and go with the stock throttle body so I can attach a TPS?
Here are the general specs:
Yes it is a NA l28 that has been turbo'd.
Engine:
- F54 Block
- Flat-top NA Pistions
- P79 Head
- Non-EGR N47 Intake Manifold
- 240sx 60mm Throttle Body
- Nissan T3 Turbo
- Front Mount Intercooler
- Greddy Type S BOV
- MSD Ignition
- Walbro 255lph Fuel Pump
- Complete 3†Custom Mandrel Bent Exhaust Piping
- Dynomax Super Turbo Muffler
- Manual Boost Controoler
- Stock ECU
- Electric Fan with Electronic Thermostat
