sergio Posted January 5, 2011 Share Posted January 5, 2011 i purshace a 1977 280z,and it did not come with a spare tire ,any one know where i could found one ,or is there a diferent tire that could fit in the back wheel, just in case i get a flat.Any information are welcome.this is my first datsun and i am trying to learn as i go. Thank you for your help.SERGE Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted January 5, 2011 Share Posted January 5, 2011 Well the junkyard is a pretty easy place to locate a spare. Just measure the well and then go trunk hopping and see what you can find with the right bolt pattern. You don't have to go with an inflatable spare, pretty much any doughnut will work so long as the size is close. A couple notes on why most doughnut spares aren't rated for highway speed: A. because the rubber isn't rated very high, and being rounded is doesn't track so well. B. With two different sized rear tires, your Differential will be working extra hard and could heat up and fail. Quote Link to comment Share on other sites More sharing options...
dangerboy Posted January 5, 2011 Share Posted January 5, 2011 I have the spare tire from my 77 280z if youre interested. Shipping would be from 20112. I also have can of air from my 71 240 to fill it up with. Seriously though, let me know if you want it. Quote Link to comment Share on other sites More sharing options...
z2go Posted January 5, 2011 Share Posted January 5, 2011 This is a good topic to be posted in the WANTED section, since this has nothing to do with technical enhancement of the vehicle. Quote Link to comment Share on other sites More sharing options...
sergio Posted January 5, 2011 Author Share Posted January 5, 2011 This is a good topic to be posted in the WANTED section, since this has nothing to do with technical enhancement of the vehicle. THANKS I just did,sorry i am novice at this. serge Quote Link to comment Share on other sites More sharing options...
sergio Posted January 5, 2011 Author Share Posted January 5, 2011 I have the spare tire from my 77 280z if youre interested. Shipping would be from 20112. I also have can of air from my 71 240 to fill it up with. Seriously though, let me know if you want it. thank you for responding,i am not showing the car,and alot of poeples do not recommend to use a spare tire that is so old,it is not safe as some of them say i am just trying to see if some one will know what size rim and tire i should buy to fit in my well in the rear trunk. thank you if you can help. regards serge Quote Link to comment Share on other sites More sharing options...
