MS 1 v2.2
98cobra+75280z
Find your best launch RPM, then set your MS soft (retard above) and hard limits around it. May have to play around with RPM and retard values till you get some that hold the RPMs steadier. 0 or negative retardation worked best for me. Also I just set the flat shift limits at redline, but retarded quite a bit. Makes some good noise.
to use launch control does it need to be wired to a switch. I don't understand how it will work and not also limit your free revving or driving rpm's with out being wired to a switch or something along those lines.?? can someone show me where to find the information, I've searched DIYautotune and the megamanual and can't seem to come across anything that explains how the launch control feature works in megasquirt. thanks again for your help
kevin
