RT Diff Mount - Necessary to notch lower diff mount?
The Woj
If you are asking me, I had bad driveshaft angles and adjusted the rear of the R200 down to correct the angles and problem solved.
Both the R/T / Energy mount and the Solid Arizona Zcar mount screw up the geometry a little- which is all it takes.
If I were doing it again I would find a shorter Energy bushing and then use spacers or washers to get back to stock geometry.
Tj
  • Replies 41
We do need to keep our eyes out for some kind of different bushing for the RT mount. I think the way we have to "notch" it to fit over the snout on the diff weakens it a good bit. I should have posted pictures but the metal inside the bushing wore thru on mine and was metal to metal rubbing on the diff. I have been pretty hard on it....
