CarolinaTZ Posted February 15, 2011 Share Posted February 15, 2011 Hey guys can you help me out. Just bought an LSD for my 72. It came with a mustache bar w/ urethane bushings. Are there supposed to be large washers where the mustache bar bolts to the chassis? It didn't come with any the way I received it. And the stock one has the rubber bushings molded into the large washers - top and bottom - frame side and nut side. Do the urethane bushings go right up against the bottom of the frame with no washers? And it seems like it needs them on the bottom too along with the small flat washer and nut. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
stravi757 Posted February 15, 2011 Share Posted February 15, 2011 yes you need to put the washer on the urethane bushings top and bottom. Quote Link to comment Share on other sites More sharing options...
ArizonaZ Posted February 15, 2011 Share Posted February 15, 2011 This is what is should look like http://atlanticz.ca/zclub/techtips/moustache/index.html Quote Link to comment Share on other sites More sharing options...
CarolinaTZ Posted February 15, 2011 Author Share Posted February 15, 2011 Thanks guys! I "could" grind the rubber away and use the stock washers but, I prefer to keep the original bushings/washers intact. Now the search begins for these washers. Quote Link to comment Share on other sites More sharing options...
