Guest richlkyl000 Posted February 22, 2011 Share Posted February 22, 2011 Ok im looking into a bushing kit for my 78 280z and im wondering what will give me the stiffest ride Quote Link to comment Share on other sites More sharing options...
jhm Posted February 22, 2011 Share Posted February 22, 2011 Any of the polyurethane bushing kits should give you the result you're looking for.....you can buy the bushings individually or as complete kits. Check eBay, Prothane, Energy Suspension, etc to see what's available. Replacing your old rubber bushings with poly is a good cheap way to improve your car's handling. If you want to make it easy on yourself, look here: "http://www.thezstore.com/page/TZS/CTGY/PSDC06A". Hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest richlkyl000 Posted February 23, 2011 Share Posted February 23, 2011 Yes this helps but idk that the car was only running rubber bushing but do you know if there is a diffrence betwween the red RÜK indestries bushing and the black ones? Quote Link to comment Share on other sites More sharing options...
jhm Posted February 23, 2011 Share Posted February 23, 2011 The only difference between red and black that I'm aware of is that some manufacturers impregnate the black bushings with a graphite product as a lubricant. Also need to consider that not all end-link bushings are the same thickness. There's LOTS on info available on this topic in the "Brakes/Wheels/Suspension/Chassis" sub-forum. Quote Link to comment Share on other sites More sharing options...
Guest richlkyl000 Posted February 23, 2011 Share Posted February 23, 2011 K thanks Quote Link to comment Share on other sites More sharing options...
