Bushing kit
Guest richlkyl000
Any of the polyurethane bushing kits should give you the result you're looking for.....you can buy the bushings individually or as complete kits. Check eBay, Prothane, Energy Suspension, etc to see what's available. Replacing your old rubber bushings with poly is a good cheap way to improve your car's handling. If you want to make it easy on yourself, look here: "http://www.thezstore.com/page/TZS/CTGY/PSDC06A".
Hope this helps.
Guest richlkyl000
Yes this helps but idk that the car was only running rubber bushing but do you know if there is a diffrence betwween the red RÃœK indestries bushing and the black ones?
The only difference between red and black that I'm aware of is that some manufacturers impregnate the black bushings with a graphite product as a lubricant. Also need to consider that not all end-link bushings are the same thickness. There's LOTS on info available on this topic in the "Brakes/Wheels/Suspension/Chassis" sub-forum.
