az240z Posted March 19, 2011 Share Posted March 19, 2011 I may be needing a 1978 280z engine harness. This should include the fuse panel,rubber grommet, and fuse link assemblies. Must be in excellent uncut condition. Engine harness only. Shipping will be to Glendale, Az 85308. According to the microfiche it was part 24012-N7000 which then became 24012-N7800 which is the one that I need. MUST BE FROM A 1978 ONLY. send pics to Az240z@hotmail.com Thanks Quote Link to comment Share on other sites More sharing options...
tyler031734 Posted March 21, 2011 Share Posted March 21, 2011 I may be needing a 1978 280z engine harness. This should include the fuse panel,rubber grommet, and fuse link assemblies. Must be in excellent uncut condition. Engine harness only. Shipping will be to Glendale, Az 85308. According to the microfiche it was part 24012-N7000 which then became 24012-N7800 which is the one that I need. MUST BE FROM A 1978 ONLY. send pics to Az240z@hotmail.com Thanks Ive got one I pulled out of my 78 for the SBC swap. It does not have the connections to the battery, where those the fuseable links you spoke of? I have all 3 switches from the box just in front of the battery, grommet for the fire wall looks good. BUT the bad for you anyways is a shop did cut the harness and replaced the plugs that all go to the thermostat block. you could solder these and make the connections disappear If you cant find anything... Quote Link to comment Share on other sites More sharing options...
az240z Posted March 24, 2011 Author Share Posted March 24, 2011 thanks. I will keep this in mind. Quote Link to comment Share on other sites More sharing options...
az240z Posted March 24, 2011 Author Share Posted March 24, 2011 pm sent Quote Link to comment Share on other sites More sharing options...
