tsabboi Posted April 22, 2011 Share Posted April 22, 2011 Alright so i'm in the final phase of finishing my clutch's hydraulic system when I find this part,I have no idea what it is called and what it does, the manual also doesn't show it, my 280zx is right hand drive too, so even harder to navigate things under the hood (proof below) So if you guys have any ideas please help i'm stuck! Part Description: Its in between the Master and Slave Clutch Cylinders, both the clutch line from the master and slave connect to this part, and has a bleeder screw. Quote Link to comment Share on other sites More sharing options...
macambra Posted April 22, 2011 Share Posted April 22, 2011 It's a dampner. So you don't drop the clutch and roast the tires. Subaru uses something similar in the STI. Quote Link to comment Share on other sites More sharing options...
tsabboi Posted April 22, 2011 Author Share Posted April 22, 2011 It's a dampner. So you don't drop the clutch and roast the tires. Subaru uses something similar in the STI. cool thanks, and do you have any idea where it should be mounted, I cant seem to find a place to mount it, although from what I been reading, I can just bypass it by going straight from the master to the slave but would suffer a stiffer pedal, opinion? Quote Link to comment Share on other sites More sharing options...
macambra Posted April 22, 2011 Share Posted April 22, 2011 cool thanks, and do you have any idea where it should be mounted, I cant seem to find a place to mount it, although from what I been reading, I can just bypass it by going straight from the master to the slave but would suffer a stiffer pedal, opinion? Depends on the clutch. I would change the whole setup to the parts from your local parts store. Or if you want to get crazy with it- search this site for the info on the different types of clutch and slave available on the different years of Nissans. Don't hesitate to use the search bar-you would be surpised by what you might find!! My 2 cents. Quote Link to comment Share on other sites More sharing options...
