echocluster@hotmail.com Posted April 22, 2011 Share Posted April 22, 2011 i know there was a guy trying a 390 swap in 2006 but i dont know if he was successful. has any one finish the swap. Quote Link to comment Share on other sites More sharing options...
390fe Posted November 2, 2011 Share Posted November 2, 2011 (edited) hi i wanted to do 390 swap about five years ago, did not happen because of life... what i do remember is there is a bell housing to fit a t56 and a dry sump oil pan involved. if you set the motor under the hood on the ground (on stock oil pan) and try to shut hood, you will see why you need a dry sump. as for power you need good heads, large carb(efi is better), good manifold, 10-to-1 compression, cam (if you use efi you can get a mean cam and have it run good). i do not remember all my build specs, but i started on that motor in 00' and it was 3-or-4 years to find all of the parts at any kind of a deal. today it will be real expensive to get close to the power this motor is capable of. by the way my motor ended up rear wheel dynoing 487 hp and 512 ft lbs good luck. Edited November 5, 2011 by 390fe Quote Link to comment Share on other sites More sharing options...
yellowoctupus Posted November 3, 2011 Share Posted November 3, 2011 Quote i wanted to do 390 swap about five years ago, did not happen because of life... Yeah, Gotta watch out for that life thing. It'll sneak up on you when you're not lookin. Quote Link to comment Share on other sites More sharing options...
