Basic Tuning MAP Needed
Two80z4me
Looking for a base tune, didn't find anything in the Sticky MAP's that was close to mine.
Here are the specs:
-MSII PCB3.57
-Stock Turbo 6psi(w/jpipe and BOV)
-L28, P79, Stock Cam, Flat top pistons (8.7:1)
-Stock FPR
-Stock fuel rail
-Stock HG
-Stock 280zxt Dizzy
-Stock 270cc ZXT injectors
-Walbro 255LPH
-3" straight exhaust
-NGK spark plugs
Thats about it, anything else that you guys might need let me know.
Brief sidenote, you can see that the relayboard is located in between the brake booster and the strut tower under the hood, is that gonna be an alright mounting location? the DIYautotune site says that its okay to have it in the engine bay, but washingtons rain and the z's sealing capabilities make me think that it probably needs a cover of some sort?
Edited by Two80z4me
  On 5/2/2011 at 10:22 PM, Two80z4me said:
Bueller? this is the most common L28et swap... someone has to have a map
I told you I would give you my flat top tune... and that it was running on my L28ET?
Also, if you have enough wire, I'd move it back to where I have mine. [This pic is of the old car/old wiring].
Edited by FlatBlack
