jessejames
    5
jessejames last won the day on September 22 2024
jessejames had the most liked content!
About jessejames
  • Birthday 09/17/1920
  • Gender
    Male
  • Location
    Toronto, Canada
Recent Profile Visitors
jessejames's Achievements
Apprentice
Apprentice (3/14)
  • First Post Rare
  • Collaborator Rare
  • Conversation Starter Rare
  • Dedicated Rare
  • Week One Done
Recent Badges
18
  1. I weighed the Z with the sr20det in it and it came in at 2395. The car has changed significantly since then. I plan to corner weigh the car later this summer. I have a spreadsheet where i track parts i've installed and removed with best guess weights. I believe the car is probably around 2521lbs, give or take. I'm not sure how much my rollbar weighs (i guessed 100lbs). I would like add a full leather interior with lots of sound deadening at some point. I have been eyeing the star road aluminum body panels. My dream is to make this car the Singer of 240z for me.
  2. Some updates. We installed a larger clutch master that was very easy to install. It solved the gear release problem with the cd009. We redid the steering shaft and motor mounts. I didn’t like the way it was installed before. Will know if it’s better in about a week or two. Installed a new Garrett intercooler to replace the eBay special I had. We reduced the intercooler pipe size down to 2.5” to see if it will help with spool. Installing a 14psi spring in the wastegate actuator to help hold boost. Will dyno again soon. We also removed the spacer from the skunk2 intake and modified the entry angle. Replaced all the intercooler pipe couplers with the vibrant hd clamps. The old pipes kept blowing off. installed dapper led seven lights. So much brighter than the halogens I had. We installed the rest of the rear t3 suspension bits. we also installed a new t3 steering rack and crossmember, along with BRE mirrors.
  3. Cool but expensive. The chronograph is $3k USD.
  4. Had the Z tuned again on 94 Octane. Still had 14psi. The wastegate spring was too soft so boost started to drop in the rev range. TLDR: 446 WHP and 389 ft/lbs
  5. Hey guys, sorry I haven't been on the forums much lately. Too busy enjoying the car. So far I have to say I love the setup. Honda parts are so much cheaper than JDM Nissan parts (having come from an SR20DET). I moved to Toronto from Vancouver and local tuners are telling me I should be able to make 450WHP on their local pump gas and even more on E85. I'm hesitant as the K24A2 is mostly stock. I believe this swap can be done on the cheap. The big issue is going to be moving the steering arm around the engine to fit the K series. The rest is pretty straight forward. I'm happy to answer any questions.
  6. We did an e85 tune, same boost level of 14psi but with more timing. We end up with 450whp.
  7. I only considered the k24 and k20. The aftermarket support and cheap prices of the engines, and their power potential was the deciding factors.
  8. Not with the cd09 transmission. If I used a smaller transmission like the s2000 or bmw zf, its possible.
  9. A lot has happened since the last update. We milled down part of the transmission and clutch cover to make it work. The oil pressure was turned down on the dry sump pump and we switched to a thinner oil. The car was tuned on shell 93 first and made 325whp at 10psi. The car was then tuned on pump gas with octane booster and made 387whp at 12 psi. An e85 tune might be down the road. My tuner is keeping the tune very conservative. When I build the motor, he believes we can hit 430whp on pump gas. For comparison purposes I have included a dyno graph of a stock 2019 Audi A5. It's a 2.0 turbo that supposed to have 248bhp. You can see from the dyno chart it's putting down about 212whp.
  10. Sorry for the delay. Between moving across the country and trying to finish this project, its been tough. Theres been alot done on the car. There's been some problems that we are still trying to sort out. We used the Collins K24 to CD009 adapter plate and flywheel. The flywheel bolts they suggested were too short. We end up ordering new bolts from ARP. We installed the adapter plate and flywheel with a ZSpeed Heavy Duty V2 CSC HD Concentric Clutch Slave Cylinder and a Southbend Street Clutch. Unfortunately the fingers on the center of the clutch are touching the outer body of the slave cylinder. The stack height is too tall even with the clutch adjusted. We might try to shave down the black bracket to make some space. We used a Serial Nine shifter relocator kit and that has worked wonderfully, and placed the shifter in the OEM hole in the transmission tunnel. We had new piping made for the intercooler and turbo and it turned out beautifully. The height of the OEM valve cover is a bit high. I might switch to the Skunk2 version for some extra clearance. The Tractuff water plate block off works well, however their alternator relocation bracket does not. The alternator twists under tension with the belt. I've noticed since I purchased the kit, Tractuff has changed their design and has a stronger bracket but they will not offer an exchange or warranty. I'll try to get some pictures of what I mean. We started the car and found we had 65 psi of oil pressure at 2000RPM, to we are going to switch to a thinner oil. I'll update when I can. Cheers Jesse
  11. The front Brake caliper brackets included with the kit, would not fit. I had to have a machine shop alter the brackets. I plan on having completely new brackets made once i finish moving.
  12. Hi ottehr, I'm in the middle of the same swap. I've got a build thread on the forum thats out of date. I was wondering how you managed to avoid the steering shaft interfering with the accessories. Could you post some pictures of that area? My CD009 is now the lowest point on my vehicle. The way it hangs bothers me, but I'm just curious what yours looks like. Thanks, Jesse
  13. I just moved across the country and I am waiting for the car to get here before I can do anymore work on it. Hopefully this spring I'll have more details. The brakes are mounted. If you look at my build thread there are some picture's.
