MMaxim
  • Location
    Portland, OR
Recent Profile Visitors
2920 profile views
MMaxim's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In
Recent Badges
0
  1. From Racetronics website: "The 1999 & up LS1 F-body cars have a pump that is inside a plastic fill-bucket. The fill-bucket is equipped with two inlets on the bottom. The equalization checkvalve is used to fill the bucket when the level of fuel in the tank is greater than in the bucket. The equalization checkvalve does not allow fuel to exit the bucket. The venturi system's inlet is a combination checkvalve and powered suction system. The factory pump supplies pressurized fuel via a small tube which feeds a calibrated jet inside the venturi system. This jet of fuel shoots across the base of the checkvalve inlet thereby creating a suction effect which draws more fuel from the bottom of the tank through the filter sock. This venturi system keeps the bucket full all the time even when the fuel tank is almost empty. A full bucket keeps the pump immersed in fuel regardless of the tank level so that when the tank is low on gas and you are doing some hard cornering or acceleration the pump does not run dry and start aerating (air bubbles) the fuel. This happens as the fuel sloshes from side to side in the tank leaving the center low on fuel. This can cause detonation and possible engine damage. The 99+ F-LS1 cars with plastic tanks have no baffling in them so the bucket is very important. The bucket also allows the car to operate with lower fuel levels in the tank due to its scavenging effect. The fill-bucket improves motor crank-to-run time as the priming time is reduced under most conditions. The return line feeds the pressure regulator on the fuel module which diverts fuel back into the bucket so that the unused fuel also helps keep it full at all times. With bucket and venturi system in place there is no need to run foam. At least that's what it looks like to me.
  2. I thought that in that particular tank the pump is sitting inside the enclosure that keeps it submerged in fuel during acceleration and cornering. The return line seems to be dumping fuel inside that enclosure, too. And you are right, the fuel level float is outside that and will not be reliable during cornering.
  3. Just what I was looking for! Thank you for posting.
  4. It is a 1975 280z 2+2. Currently stripped to bare metal awaiting a coat of epoxy primer. Have been collecting parts for the last year and a half. Have all the major components taken care of. Mike
  5. Jim, I have been following your build for a long time. Awesome work! One of the best Z I have ever seen! Your thread is the main source of information for my build. Thank you very much.
  6. A little update. Local supplier ordered that for me. Worked good on rear hatch lock, I assume doors will be the same. Ignition might be different. Paid $38 for the kit.
  7. Thanks. That was the first thing I did, but I haven't found a locksmith that would sell me some parts. 2 guys that I spoke with only wanted to rebuild/rekey for about $60 per lock. I have the locks apart and just need some parts, so $60 seems a little excessive when I see wafer kits for other cars being sold for $20-$25.
  8. Hello everyone. I have a '75 280z with mismatched locks. Have been trying to find pins (wafers) to re-key but it turned out to be quite impossible. Do any wafers from newer cars fit our locks? Any ideas? Thanks in advance.
  9. Just received a response from Ground Control Suspension. "Hello Michael, I apologize for not being able to reply sooner, my e-mail was down for a few days. Our system adds approximately 1" of tire clearance over the original springs and perches. Thanks, Donovan" Hope this will help someone.
  10. Hello, everyone! New 1975 280Z owner. First post, but I have been reading on this forum for years. Couldn't find the exact information I was looking for while searching. I need to know how much clearance will I gain with Ground Control coilovers. I would like to run 16x9, 0 offset rims in the front and I am lacking about 20 mm of clearance. All posts I have read say that coilovers give more clearance without the exact measurement. With stock suspension in the car I have 122 mm (4.8 inches) from the wheel mounting surface to the spring perch. Appreciate your input.
