Let me see you exhaust shields
tooquick260
photobucket-52477-1360886328006_zps3bfcd
Wrapped the manifold.
Bought a housing/blanket for the turbo (had to be slightly modified to fit the wastegate actuator.)
Wrapped the downpipe about 1.5 feet  Stopping just before my wideband O2. (picture shown is before I welded the bung. So not shown)
Edited by OldAndyAndTheSea
Looks Good@
I should have done mine before installing. I will put the blanket on the turbo though. I was thinking of copying the stock heat shield from my N/A setup.
OldAndy, what are you doing about your breather coming off the engine. Are you going to vent to a tank?
Thanks.
You'll definitely see the difference with the blanket. That's for sure.
And if you're talking about the PCV. I kept the stock system in tact, at least from the crankcase to the intake manifold. Since I am using a N42 intake, I had clearance issues with the PCV valve and the turbo compressor housing.
I plugged the existing PCV hole, and drilled and tapped one of the old heat shield mounts for the new placement, clear of the turbo.
I had to shorten an oem hose. These pictures will better explain it.
Relocated PCV on N42 non egr intake manifold.
Initial OEM hose (from a 1976 280z)
photobucket-42309-1362429257835_zpsa2861
"Modified" haha
photobucket-42326-1362429289661_zps53063
and installed.
photobucket-41238-1362430205235_zpsf8a83
As for the valve cover. I'm just using the 5/8" K&N air filter.
