RB CAS drive gear replacement info.
  • Please log in to reply
63 replies to this topic
#61 stony
stony
    RB Moderator
  • Super Moderators
  • 4285 posts
  • LocationSyracuse Utah
Posted 04 December 2013 - 02:26 AM
Hope you don't mind but I thinned out your thread and merged it with mine that is stickied. I think this is good info for all that consider doing this.
5.3 truck motor, BTR stage 2 cam, BWs480, custom intercooler, AEM Infinity, 2 speed powerglide, Fully built Ford 8.8, 4:56 gears/spool, 4 link suspension.
#62 HowlerMonkey
HowlerMonkey
    Member
  • Members
  • PipPipPipPipPipPip
  • 1374 posts
  • LocationWest Palm Beach
Posted 04 December 2013 - 09:34 AM
Are we satisfying the ecu in question concerning setting base timing and have some way to see that timing on the front pulley?
Some ecu of that family have a 5 degree timing change at idle depending on ground to a certain terminal.....usually from the park/neutral safety switch that retards timing 5 degrees.
This is on ecus that came from automatic sourced cars.
#63 Vandergriff84
Vandergriff84
    Always Here
  • Members
  • PipPipPipPip
  • 105 posts
  • LocationRaleigh, NC
Posted 04 December 2013 - 09:52 AM
Sounds good Stony, I hope this helps someone else out. I had read about three other threads on different sites that describe the exact same problems I was having but no one ever posted a solution so I post on all of them hoping to get a response but none the less I was on my own. I have also read that if the half moon pin is broken that the wondering signal will result in a massive retard in timing from the ECU.
Just as a side note to all that are planning to do this swap. Take the time to find a reliable and honest source for the motor before ordering. I bought mine from Canada and when it arrived, everything on the exterior was broken. I know that most of the importers don't warrant against exterior parts being broken but I have spent over a $1000 replacing what was broken on mine and as of now a whole lot of time because the cam drive pin (which is technically attached to an internal part by the way) was part of what was broken. I would also recommend asking for pictures of the motor before ordering so that you know what you should be getting.
Edited by Vandergriff84, 04 December 2013 - 09:54 AM.
Skylady Z - 74 260z RB25det
#64 stony
stony
    RB Moderator
  • Super Moderators
  • 4285 posts
Posted 04 December 2013 - 01:58 PM
Agreed, Best way to go is get it out of a running clip. 9 times out of ten when you get it from japan it has come out of a wrecked car. if it was a front hit there is a good chance the water pump tab on the black will be broken off.
Howlermonkey the conversation about timing was a legit conversation... i weeded most of it out because even though it was accurate it wasn't related to the problem as a whole in this thread. The issues I had and the stuff that V went thru are pretty much everything that could go wrong with the cas drive gear replacement and hopefully will prevent any excessive downtime for anybody in the future.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
