cosmo
Turbo distributor assembly
I completely disassembled my turbo dizzy to clean and paint it. However, now I am not 100% sure how to put everything back together correctly. :-D
After putting it together there is quite a bit of play in the input shaft so the trigger disc can touch the sensor.
FSM didn't help
Thank you!
Edited by cosmo
Share this post
Link to post
Not a whole lot to it. Sure you didn't forget a shim or two?  . I just looked at my BNIB unit and it looks like there is a shim between the lower shaft collar ( that engages the oil pump spindle ) and the dizzy body. There is absolutely no free play on my dizzy shaft..... well maybe a couple of thou" . No way trigger disc should hit Optical sensor
Share this post
Link to post
I think you're missing one or two of the shims in this diagram. Illustration number 22160. Part number for 1982 - 1983 Turbo shim kit is 22160-P9000 . Illustration below is for 1981 Turbo Dizzy.1982 -1983 Dizzy has these two shims, but I could not find an appropriate illustration. 1981 shim kit is 22160-M5600. bad news, both shim kits are NLA. You can scrounge used Datsun dizzy's for these. The shaft diameters are often the same.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
