Sign in to follow this
Black_label
Distributor wire frayed
Good morning guys, I was in the process of changing my ignition coil, when I noticed one of the wires leading to the distributor was cut. In addition one of the ring connectors on the resistor ballast in a rubber cover also broke (blue wire).  The car would run before but now it won't start, so I'm blaming these two issues. Would I be able to splice the wires back together or should I be in search for new wires? Any info would be greatly appreciated.
Share this post
Link to post
You can splice them.  I'd use a butt connector and shrink tubing myself, but many people like soldering.
The engine won't start because the blue wire is the signal to the EFI computer.
Share this post
Link to post
Is the cylinder necessary? Can I bypass that also?
Thank you for replying so quickly
Share this post
Link to post
Posted (edited)
47 minutes ago, NewZed said:
Why not just fix it?  It's a capacitor for reducing electrical noise.  It has a purpose.
I didn't know the name of the component, thank you for the info. I'll look into repairing it.
Would that be the exact name?
Edited by Black_label
Share this post
Link to post
Typically, it's known for suppressing radio interference, buzzing, so it's not really necessary.  I've used them to make my tach work right though.  Electrical noise can cause problems.
Looks like any alternator condenser would work.  You can get them at the local auto parts store.  Not a huge deal though.  There are two #23's.  One at the alternator and one at the coil.
http://www.carpartsmanual.com/datsun/Z-1969-1978/electrical/radio-stereo-clock/from-aug-76/23
  • Like 1
Share this post
Link to post
The wires broke off on mine, so I ended up using one similar to this (I think it's supposed to be for an F100 or something) https://www.napaonline.com/en/p/ECHIH200
Basically any large-ish capacitor will work. It's not expressly necessary for the car to function, but as mentioned it helps to clean up electrical noise and reduces interference in the tach and radio.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
