Well, first of the lt1 is better suited for boost than the ls1. the lt1 head is a traditional SBC head with 5 head bolts per cyl. the ls1 only has 4. The LS1 make alot of power NA and on nitrous. Building an lt1 is cheaper than an LS1 for power. and Opti sparks tend to go out real quick if you rev the motor hi alot. these are all things to consider i'm sure there's more but i'm hungry and have to go eat lunch.
Check LS1 tech in the FI section alot to learn about Boosting the LS1 engine.
how's the leg room under there? Because of my cam choice i'll have to run a vacum canister because the engine doesn't rpoduce enough so i rather just go with a better pedal assembly and ditch the canister.
for .1 inches i would have started grinding at something.... the performance gains if a ls1 to an ls6 is about 15hp and abou the same in tq. that ls1 manifold really dies uptop.
Is anyone running the wilwood/cnc/tilton pedal assembly? I was thinking of doing the single clutch dual brake assembly to eliminate the need for a booster and have the front and rear brakes each with there own master.
My biggest concern is with fitment because i'm tall and room is already limited under the dash so i want to retain a comfortable driving position.
Any input is welcome.
Here is an example http://www.wilwood.com/Products/005-PedalAssemblies/002-FSMP/dual/index.asp
ZFIRE-15-20K thats way to high i've done the numbers with 20% contingancy for this build including suspension and body work and i'm at about 12k
Dale- the LS6 intake isn't any larger than the ls1 intake, atleast not that i've seen. the FAST manifold is about .5" taller than the ls6 but thats about it.
I'm going to look into that......
I've pulled Many Vette Motors and that Oil Presure sending unit does not look at all familiar. Is that a datsun one? Mine has a norrmal 2 pin sealed connector.
I wouldn't mind some reduced ground clearance. i'm use to driving a slammed C5 so that won't be an issue. I was looking at the Pacesetter camaro headers and they might work but i'm not to sure.
Ok I Spent 3 days using the search function and trying to find as much info as possible on Long Tube Headers For the LS1 and wasn't able to find anything.
I'm having a LS1 w/ t-56 swaped into my Z and have not found anything regarding longtubes for it. I' know how important headers are to the LS1 my C5 gained 20rwhp and 25lb/ft tq when i installed my Kooks Headers.
Does Anybody know of anyone who makes longtubes headers for the LS1 in the Z.
Or does anybody know of any F-body headers that might fit?
Oh ok, well i;m not really planning any Hi torque launches seeing as how my motor really won;t make any real power till about 6k.
Can someone post up a list of what is needed for the swap. I would like to get them form one souce at one time if possible.
How Much Stronger are CV's than U Joints?
What all is involved with a r200 U joint Conversion... i've searched but i'm looking for parts. Does any vendor sell a complete kit?
Well thats good to know about the body diffrences. The car is a 71 240z.
Who makes a good 6-8 point weld in cage for the Z bodies. How about those sub frame conectors.
I know and i respect what your saying... i actually have a 04 c5 vette and an 02 R1 as my DD and it use to by my race car (hence being tired of breaking transaxels) is there a power stering module available for Z cars. My 240 doesn't have PS and it would really help.
Any other sugestion to make the frame rock solid.
I Live Out in Riveside County and on the Few Ocassion we do race on the freeway we pick a stretch of the 15 freeway@ 3 AM where there aren't any on/off ramps for 5 mile and it's pretty dam straight...
But i know what you mean.
Do you mean a full cage, or just like a 6 point with door bars, or a 8 oint with 2 main hoops.
Does anybody have any experiance with the Jegs Tube Fraim Kit as far a assembly goes?
Hey Guys I did a Search woth no luck, what it the tq/hp limitation on am unmodified 280z Body and frame.
Short Of going Tube Frame/12 point cage, what can be done to strengthen the chassis and keep it from bending like a bow tie?
thanks, i'll look into the msa 4 core. actually i might even do a custom V mount depending on how crazy i'm ffelin once the motor is off the stand and in the car......
Oh the possibilities......
