d3c0y
d3c0y last won the day on January 13 2014
d3c0y had the most liked content!
  • Gender
    Male
  • Location
    Gold Coast, Australia
Recent Profile Visitors
3479 profile views
d3c0y's Achievements
Newbie
  1. That how close the RB head is too. On mine the timing has just been converted to a belt over the chain.
  2. So is something like the Top End Performance triangulated STB going to work ok?
  3. I went to StarRoad in 2012 and saw this car being built and heard it cold start which you can see here: https://www.youtube.com/watch?v=jBdyYMeRiiY I can back up the 320ps claim, as that is what i was told by the mechanic when i was there. The carpet on the dash is just a dash mat the interior on that car is immaculate just like the rest of it. The car has had 50mm Solexs on it too. I took some pics at StarRoad including ones of this yellow car while i was there. You can see them here: https://www.facebook.com/media/set/?set=a.528519113876391.1073741829.277779232283715&type=3 FWIW, I have a 3.4L L28 that makes as good as 360hp and 300ft/lbs at the crank and runs on pump fuel in a street registered car. Build is here if you are interested: https://www.facebook.com/media/set/?set=a.553626791365623.1073741831.277779232283715&type=1 Video: https://www.youtube.com/watch?v=_Vs7_89toUY It idles fine too btw: https://www.facebook.com/photo.php?v=505700526158250
  4. You just need to take the flange on the front of your stock R180 and put it on the subi one as they are different.
  5. If you are interested in knocking up a few sets i know a few of us in Australia that would be keen on buying some.
  6. Come over i'll take you for a ride
  7. Hot tip to save you a bit of time, AZC alloy sumps dont fit in 280ZXs! :P
  8. Yes it will be running on crappy pump fuel. No one but Simon seems to like my engine
  9. For what it's worth those calipers are the same as 300ZX twin turbo calipers if they are the sumitomo calipers. If they are Brembos off the V-spec II then they are still the same bolt spacing on the mounting ears.
  10. Any reason you havent looked into getting some more head work done and getting a bigger cam? Even if you go turbo you are looking at spending in the thousands more. Maybe a 300 duration 500 liftish cam with the appropriate headwork will give you enough hp to keep you happy? Everything about hotting up Lseries N/A always seems to come back to one thing - how much you can make the head flow. With the forged pistons you will be able to rev it harder too and that's how N/As make power.
  11. You dont have to even use S13 coilovers. Have a look around and do a bit of research yourself. I'm using HKS Hypermax Performer coilovers from a GDB Impreza. You just need to find a pillow ball type top and 2" diameter body with a height adjustable body (dont confuse that for spring preload adjustment). From what i saw in the wreckers at Japan is that most coilovers are esentially the same - they just bolt different tops and bottoms on the bodies. If you look at the picture these HKS coilovers have much thicker shafts than most of the S13 dampers too.
  12. Hey Guys, I'm building an as close to 3.0L as I can get, high rpm, forged internal L28 with a stock stroke. I have both N42 and F54 block at my disposal and want to know definitively which is the best one to go with baring in mind it will be running an 89mm - 90mm bore size. I searched as hard as i could on this one and didnt really come up with anything solid on the subject other than a few suggestions the N42 maybe the way to go. I thought a thread with all the info in one place would be a handy thing to have anyway. Thanks Jake
  13. ... that can be found here
