Here are some photos of the 5MT with an OBX in it, but it doesnt show the orientation of the gears:
As you can see, the axle splines are on the diff itself, as the axles do not clip in, but are attached via compression pins.
Will I need to shim the diff, from side to side, axle to axle? Shimming the bearings I mean?
As you can see in the photo, the bearing looks to be pressed on all the way to the housing.
Will I need new bearing for the axle shafts?
New seals?
I also have the kit from RBryant. I hope that hardware works!
