Dry sump has been touched on in some past threads but I'm needing some feedback on my idearrrs. First thing i need to establish is that i'm set on dry sump, the addictional cost over an aftermarket oil pump is well worth the insurance provided by dry sump IMO. So now to my proposed plan. I'm only planning to run a 3-stage setup, 2 scavenges in the pan and one feed going in where the oil fitler is. I would like to just canibalize the gtr pan, or atleast use the flange off of it, since it's a pretty good base to work with. I'm also going to be using the tomei oil gallery restrictor to help remedy too much oil staying in the head. I have sketched out a rough idea of what i'm thinking about for the pan http://fragyle.net/bizerk/pan%20idea.jpg.
I'm not sure if the oil pump itself acts as a front seal or what so until i can find that out i'm staying away from making a block off plate for the old pump. So, i guess my plan for the time being is to just gut the pump and leave it.
I'm also not sure on how to size the resevoir tank. Is the resevoir tank need to be sized based on certain criteria or can i just use a off the shelf tank.
Another thing i would like to do is add a small accusump for pre-lube, but i dont have any knowledge on how good that would work in conjunction with the dry sump or what size would be needed.
I'm a major noob in this department since i have zero experience with dry sump setups. I'm only going on what i've researched and what little i've seen in person. Any feedback is greatly appreciated.
Thanks,
Brandon
