        onefast87
                Posts53
Everything posted by onefast87
	Looking for 4 clutches to beef up my clsd Looking for a price shipped to canada T1k 7e9
	2JZ piston are 86mm Vg30 piston are 88mm your going to have to have them made custom anyways, why not just buy vg30 piston's, there are several companies who make pistons for the vg. come over to z31performance.com/forum/ the guys there can sort you on what you want.
	So possibly soon time for Megasquirt (opinions)onefast87 replied to RUZN's topic in Z31 Series - 300ZX I am running a MS2 3.57,using the distributor and stock coil on my 87. all it took was a 1k resistor to "find" the cas signal, the rest was straight forward. I bought mine pre assembled from Diyautotune.com. i bought the 3.57 so no more soldering, just jumpers. I have been running my car for 2 years on 10psi no wideband, it has not blown up yet.Its a great system but tons of reading is required to understand everything. im not a master by any means but you can pm me with questions.
	i hope so, im debating switching my 0.70 housing for and 0.81. Haven't decided yet.what do you guys think?
	wait it out man. i live in canada,( not that far from the US) and sometimes i have had to wait 2-5 weeks for my parts to show up.Patience, i would try to contact him also. GOODLUCK
	Finally saved up enough money to buy my turbo. here it is. Turbonetics T72
	are you sure about this?? because i installed a 3.54 gear set into my CLSD. no problem at all.
	i dont know, i just want to make sure that i have a bullet proof igniton system. i plan to make over 700hp. anyone having success running 6 coils using 3 bips?
	hey guys im looking to trash the distributor. i have a set of electromotive coils i would like to use. http://www.crespocams.com/servlet/Detail?no=19 now i understand i need something to fire the coils. here is where i need some input.after reading it sounds like the megasquirt can fire 6 coils using extra vb921/bip's. but then i came across this...(also i dont want edis, i need spark cut) http://cgi.ebay.com/ebaymotors/4-channel-Coil-Driver-Igniter-Module-for-Megasquirt_W0QQcmdZViewItemQQcategoryZ33689QQihZ002QQitemZ120381183514QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/4-x-Coil-Driver-Igniter-Module-for-Megasquirt-VB921_W0QQitemZ150328416191QQihZ005QQcategoryZ122139QQssPageNameZWDVWQQrdZ1QQcmdZViewItem anyone have any experience with one of these? the price is reasonable.
	http://www.z31performance.com/forum/viewtopic.php?f=3&t=2536 best z31 forum hands down!
	do you really need a surge tank? the stock fuel pump may be able to keep up, i dont know much about the factory pump, but you can always get a walbro for 100$, that will keep up.
	This is my 87 NA project car! its going to be a work in progress. Mods to Date 84 Turbo Engine 88 Turbo Transmission(aka Indestructible) 86 T Rims Greddy Type R Fidanza 11lbs Flywheel Act Street Kit Quest Alternator Oil Cooler/Relocation Kit Cusco Type Strut Bars Afco Radiator 12" Efan 3" CM Exhaust with a HKS HI Power AutoMeter Boost, Volts ,Mechanical Oil Gauge MegaSquirt-II Engine Management System 3.57 3bar map Poly Engine Mounts CLSD, with a 3.54 gear ratio HKS Hi Power 3" muffler New Megasquirt II 3.57 Alpine Deck Fuzion's 245 50 16 Gutted Plenum Stuff waiting to be installed Siemens 870cc Injectors Garrett T4 T04E 3" intercooler 31x12x3 Innovate LC1 Satan T4 Manifold Innovate LC1 Aeromotive FPR Greddy EGT Still need.. Synapse 50mm WasteGate Fuel Rails Fuel Pump Oil Feel and Return line Turbo Fittings
	This is my 87 NA project car! its going to be a work in progress. Mods to Date 84 Turbo Engine 88 Turbo Transmission(aka Indestructible) 86 T Rims Greddy Type R Fidanza 11lbs Flywheel Act Street Kit Quest Alternator Oil Cooler/Relocation Kit Cusco Type Strut Bars Afco Radiator 12" Efan 3" CM Exhaust with a HKS HI Power AutoMeter Boost, Volts ,Mechanical Oil Gauge MegaSquirt-II Engine Management System 3.57 3bar map Poly Engine Mounts CLSD, with a 3.54 gear ratio HKS Hi Power 3" muffler New Megasquirt II 3.57 Alpine Deck Fuzion's 245 50 16 Gutted Plenum Stuff waiting to be installed Siemens 870cc Injectors Garrett T4 T04E 3" intercooler 31x12x3 Innovate LC1 Satan T4 Manifold Innovate LC1 Aeromotive FPR Greddy EGT Still need.. Synapse 50mm WasteGate Fuel Rails Fuel Pump Oil Feel and Return line Turbo Fittings http://i2.photobucket.com/albums/y1/RaGePwNs/fpregt002.jpg
	nice setup do you suppose this spark map would work for me aswell. i have an 87 300zx, with an 84T motor, running on 8-9PSI.
	Turbo guys who have upgraded injectorsonefast87 replied to bumble zee's topic in Z31 Series - 300ZX nistune is about the only way to accomplish that. or better yet buy a megasquirt
	how do i get a general idea of what my afr is with a narrow band 0².
	i do but its not a wideband
	i should have mentioned that i have a VG30ET. thanks for the help guys, my car is more drivable now, but i still am way off in the accel enrichment. when i am driving i can hear sputtering in the exhaust, is this caused by the accel enrich? i dont see the LED flashing when the pops happen.
	anyone want to point me in the right direction for adjusting the accel enrich? i never punched in those settings, they must be factory. thats odd, i set it to MS2 but it shows up as microsquirt, i will re burn it. thanks guys
	naviathan, i am blipping the throttle just to show that it jumps very high upon hitting the throttle, i understand it will shoot up but it spikes so high it cuts out almost.here is my msq. megasquirt2886.zip
	heres a datalog i took earlier datalog200806032030.zip
	UPDATE ok i got all 6 injectors firing now, but now when i hit the throttle, the pulse width jumps off map, then it stables off, the car sounds like its sputtering now. what would cause the pulse width to jump off the map?
	k guys, i sent off my MS2 for repairs when i blew the VB921, and when i got the mS2 back my runs runs very poorly. i have figured out that one injector bank is not firing. i have tested the Q1 and Q5,and they both give me a reading. is there anything else i could check? so far ive checked the fuses, updated to the newest firmware 2886. any help would be nice. im running a MS2 V3.0, using the stock z31 cas,running a single coil.
	there is no need to test anything.................. ive got lots of bad solders too on this board. where is a good place to have this thing repaired..
