s30zgt
Location
los angeles
Recent Profile Visitors
s30zgt's Achievements
0
On the brochure i posted above, the L24 they have listed runs a compression ratio of 10.5:1. Ive searched for more info on this engine and from what i read, they didnt release this engine due to tightening emissions regulation. Does anyone have any detailed info on this engine and how they were able to run 10.5:1 safely back in 70's? Was it ever released or even exist?
Ok great. One last question. I still have a lot more to research on this part but which camshaft would be better to use? The e88 cam, the mn47 cam or invest in a aftermarket cam? I know the e88 cam is externally oiled so if i used that one i would have to install a spray bar into the mn47. The mn47 cam was probably focused on lower rev range power and fuel economy so it probably not the right cam to use compaired to the e88 cam right? Thank you again for all the advice.
Yeah i wanted to use the MN47 since it was a high quench design for detonation resistance, had injector notches, and steel valve seats already installed so it would have most of the work done that i would need on my e88. My plan was to utilize the stock flat tops that come with the l24 block. Are you suggesting that i get custom pistons that have matched dish to decrease compression or a slight matched dome to increase compression?
Over the weekend this I pulled this MN47 off a 1984 Nissan Maxima. I have a 07/1971 240Z with a e88 head L24. Its in need of a rebuild and thinking that the e88 will need work anyway, I thought it might be a good idea to work with a head with a better starting point. I like the idea that i can use my SU's in the mean time and switch to O.E.R carbs or their Sports Injection ITB setup later down since it already has injector port notches. This is the first time I've pulled a L series head so while it looks good to me (no corrosion,no cracks) and i will be taking it to a machinist eventually, I was wondering if there are any glaring issues with this head. Here are a few pics of the head. Ive read as many MN47 threads as there are on hybridz, but most were about using them on a L28 block with flat top pistons and the resulting detonation, retard timing, and general issues with that combo but nothing about using them on a L24 block. Most of the info i could glean on using it on a L24 block is to eyebrowing the block or risk the valves self clearing themselves. This is kinda what im shooting for in terms of power on a safe and reliable engine. Im not too concerned about the power number but using it more as a personal benchmark. From the OZDAT engine utility, my compression ratio should be around 9.79 with a 39cc combustion chamber which is what ive read to be the size on the MN47. From the info Brapp posted, its better to run a lower compression ratio with full advance timing than it is to run a higher comp and have to run the timing retarded. From anyone experience, is 9.79 comp ratio as safe number to run the correct timing or will I experience pinging and have to retard on a MN47/L24 block combo? Thank you all for your help and insight.
A few people here have done it. plenty of people in japan have done it http://forums.hybridz.org/topic/93583-commonsnapper-3rotor-240z/ http://ameblo.jp/khrono8473/page-2.html#main cool but nothing new.
Dapper lighting HID's with upgrades and extended cables $325 price dropped to $315 http://losangeles.craigslist.org/wst/pts/3768353443.html
Wow I didnt know about that with the Tein's. My friend had a set of their coilovers for his ek9 hatch for several years and we never had any issues of rust or failures, and this was back in Houston, TX where it rains every other day and is at a constant 100% humidity. That was back in the early 2000's so maybe their quality has gone down in recent years? Any part in particular where rust has been known to happen? Top hat? Spring? adjusters? All over haha? Ive never had any experience with Aragosta parts, though my other friend has a g35 with Top Secret's coilovers which i believe Aragosta supplies and he is pretty happy with them. He got them for around 3500.
I did a search and didnt find anything on tein coilovers specific to the s30 model. Came across these while researching options for my suspension. Just wanted to share the info. Tein made to order info: http://www.tein.co.jp/e/products/spd.html reference data for completed orders: http://www.tein.co.jp/spd/spd_search.cgi?lang=en Protec Aragosta coilovers: http://www.protec-s20.co.jp/gtr/aragosta_s30.html With the yen artificially devalued, the dollar is a little bit stronger. so if you have the money...
Blowing fuses (no dash lights)
s30zgt replied to s30zgt's topic in Trouble Shooting / General Engine
ah my mistake. i will check that end of the harness and make sure nothing is grounding improperly. -
Thanks guys for the suggestions. Domzs, the bypass was to simply plug the wires that go into the dimmer into each other. Those wires have to pass power through each other, either directly or through the rheostat, in order to power the lights on the gauges according to the wiring diagram. With those wire disconnected i have no other issues with any other lighting or fuses popping. That is a good trick Zinpieces. i will have to try that. We are talking minimal damage since the power is running through the lamp right? it was popping that 20a Parktail fuse in seconds. Just so i have this clear. According to the diagram on the fsm, power from the alternator flows (WR wire) through that 20a ParkTail fuse through the (GL wire) to the combination switch, then is bridged by turning the light switch to the 1 or 2 position, then flows on the (GW wire) to the rheostat (RL wire) to send power to the illumination lights on the gauges. Is this correct? And if so, wouldnt the issue be after the rheostat along the (RL wire)? Is it possible that the power is grounding around there and pulling more power through the Parktail fuse and causing it to blow? Thanks again for all the help. -
Hello I recently reinstalled my dash and harness. I turned the car on and flipped the lights on. Headlight, tail lights, turn signals and side markers all worked but my dash had no light. When i turned the dimmer (rheostat) to high i heard what sounded like a sizzle and saw a puff of smoke through the dash. I immediately turned the car off and checked where the smoke had been coming from. Turned out that the rheostat had fried. Thinking it was just a bad rheostat, i read that it can be bypassed so i connected the wires together and turned the lights back on. This time the Park Tail fuse popped and once again i turned the car off. I went back over the wiring diagram, making sure no connection was loose or corroded on the dash harness. I also searched the web and took care of all the known issues like the turn signal grounding improperly and corroded side markers hoping that would take care of the issue. Once again the Park Tail fuse popped. Then i tried to isolate the problem by disconnecting all the exterior lighting (head,tail, turn, side markers and inspection light). This time when i turned the lights on it popped the fusible link on the starter. The previous owner swapped it out for one that uses 30a ATO fuses. I have a friend bringing a voltmeter this weekend to help find out where our problem lies but I want to know if you guys see any glaring issues that pop out at you? Could it be the voltage regulator? Maybe a bad ammeter? Any help would be appreciated. Thank you. oh and this is the lighting diagram im using in addition to the FSM diag. http://www.atlanticz.ca/zclub/techtips/wiringdiagrams/240z/1971_240z.gif
