When I first got my 1978 280z, it had the notorious rearend clunk. The PO had cut up old tires and used them as bushings. Scary. However, after a full Energy Suspension poly bushing set, it still had the clunk. Then I replaced the u-joints on the stub axles since they were a bit loose. The driveshaft had already been fixed by the PO. Still had the clunk. Then I found that the long bolts that hold the front differential mount in place had backed out about 1/8" and were stripped. After replacing the bolts and the differential mount, guess what? It still has the clunk. I've checked the bearings and spindle pins. They look fine. The differential has no excess play.
Most likely, it is the struts or strut mount. I'm tackling those, the wheel bearings and spindle pins next week.
So, this is all just to say that there are many things that can cause the rearend clunk. I've found several problems but haven't rooted out the culprit... yet.
