As you know, the actuator spring pulls the rod in so you use a stiff coil spring to help pull it out so it doesn't require as much boost to push the actuator open. Mine had an adjustable rod so I unscrewed the coupler and tapped longer threads onto the diaphram end of the rod to screw on an adjusting nut. The spring then goes onto the shaft against the diaphram housing, then a washer and adjusting nut. I found by using a really stiff spring I could run the boost at 15 psi or less until I was able to ad more fuel. Since then I have been able to run 25+ psi with without detonation partially due to water/alky. Everyone that has used one on the 2.3 Ford has found that 15 psi with the Holset has as much power as the stock t3 at 20+ psi. I was told it was due to the cooler/densor air charge due to improved efficiency. Surprisingly I noticed only 1 or 2 hundred difference in spoolup rpm. Norm.
