I have come a long way with this car but can't figure this one out. Cranks right up, sputters, black smoke, the smell of gas is strong. It runs OK but rough if I drive it.
Recently cleaned a lot of crud out of the tank.
Replaced plugs with NGK
New wires, cap rotor
New CHTS
Cleaned all sensor connectors.
Replaced all vacuum lines
Fuel pressure is running at 30. When I disconnect the regulator vacuum line it pops up to 34 so it appears the regulator is working properly. There is no gas in the vacuum line. When I stop the engine the pressure gauge pops immediately to 25 but doesn't move, even after several minutes. Thinking the injectors are NOT leaking.
Also the vacuum is running low. It's between 5 at rough idle and 13 at higher rpm.
I'm wondering if the injectors are dirty and staying open too long. We had the car running well BEFORE I drove it the first time. I'm guessing the drive shook up some of the crud in the tank (there was a LOT!) and caused the filter to clog. I'm also guessing some of the finer crud got through and has clogged the injectors.
Put a can of Seafoam in the tank and let it idle for 40 minutes. I don't think it helped at all.
Not sure what to try next...
