steve72z
About steve72z
- Birthday 03/15/1974
Gender
Male
Location
Bakersfield CA
steve72z's Achievements
10
I saw one a couple of months ago in Walnut Creek, Ca. The owner drove past me (10') and pulled into his garage. I have always loved the originals. I have though about buying a kit for years.
That's good, I almost fell out of my chair reading your posts.
I have had my Z for around 12 years now. The first 2-3 years the Z was my only transportation. I kept a can of starting fluid behind the seat, gave myself an extra 15 minutes to warm it up and then went on my way. I drove from Bakersfield to Santa Barbara 5 days a week (~300 MI round trip). I never had many problems with the Z breaking down. I love my Z and can't wait to get it on the road again. New cars are great for the family but theres nothing like blowing the doors off mustangs and camaros/Firebirds with a 6 cylinder.
What is the easiest CAD program to learn? (Don't have a clue)
steve72z replied to a topic in Non Tech Board
Excellent choice, I have been using CAD since ~1992 (Release 12). Something to think about is how the skills you learn will benefit you later. When I first took CAD classes I had a desire to go into Architecture. The past 14 years have taken me into the electrical and communications industries. AutoCad has helped me to secure employment with well respected electrical companies. What I am trying to say is I believe you are making an excellent choice due to the number of future prospective employers which may value your AutoCad skills. Good luck -
Looks good, Just curious I saw how you attached the lines to the tank. I am assuming the lines shown coming out of the tank are the supply and return lines. did you seal the factory vents leaving only one to vent the tank. Also I am ready to complete the same work right now. Where did you get the weld in bulkheads for the -6 lines into the tank. I am assuming these are a common item but I am not sure exactly what to ask for or where to get them.
what a beautiful Z! (not for the weak of heart or stomach)
steve72z replied to JaysZ's topic in Non Tech Board
Its hard to believe someone would spend money to make a car look like that. -
I would be interested in the rear bumper if you dont use it. PM me if you want to sell it. Congrats on the car looks like a killer deal.
I am not an expert but have some knowledge from hanging around a friends paint shop. He specializes in high end muscle car restorations. From what I have seen with cars taken down to bare metal you will need to go over the entire car with a mild acid product such as rust mort or similar. Use a green scouring pad after applying the acid to the body use moderate pressure to clean the surface. This will remove all oils and any surface rust that has started. Rinse the car extremely will with water and dry with compressed air immediatly. This will take some time to get everything completely dry. I have heard of some alkali products that can be used to deactivate the acid but I have never seen it used except in rinsing tanks. Next primer the metal with a high quality rust inhibiting primer. I believe my friend uses Valspar but I am not positive. Don't go cheap either you get what you pay for. Next I believe you should scuff the surface before doing applying any blocking primer. I am assuming any metal work has already been completed or will be prior to primering. One of the best products he uses is Valspar blocking primer 21N and the associated reducer and hardener. You can expect to pay over 100.00 per gallon for the primer, reducer, and hardener. but the primer is very thick and blocks well. The directions say not to use reducer but you will have to in order to thin it enough to get it out of the gun. All products can be found at a good paint shop. Again I am no professional so take the information for what its worth. Good luck.
That was funny MatMan.
Finally got the stroker with the lightened pistons in the car! (PICS)
steve72z replied to 1 fast z's topic in Nissan L6 Forum
Wow that engine looks great, Excellent work. About the fram oil filter: If you take a fram oil filter apart and lay out the filter material and compare it to say a wix filter you will find the fram filters have significantly less filtering capacity. This is true of the air filters as well. At least this was the case about 10 years ago, I don't imagine anything has changed. -
rust evaporator says eats only the rust, leaves clean metal
steve72z replied to waynekarnes's topic in Body Kits & Paint
Not sure about that product but similar products such as Rust Mort work the same way. They are a mild acid that attacks the rust. A friend of mine does high end muscle car restorations and uses these products in areas where the rust in not bad enough to warrant cutting in a new piece of metal. I have used the products myself several times with good results. The rust will actually turn and stay black. Keep that stuff away from paint though. I used it on my suburban and accidentally got some on the paint, left a nasty stain that I couldnt get out. -
I believe the 301 was a short stroked and decked 400 block. This engine was used mainly in the firebirds and was offered as a turbo as well. This engine s not well liked by most pontiac people. If I remember correctly the heads changed between 64 and 65. I have a 64 Tri power GTO and my tri-power will not mate up to the post 65 428 heads I have.
List your dumbest auto related screw up
steve72z replied to Workinprogress's topic in Non Tech Board
I pulled my toyota work truck into my driveway, ran in the house to get something I forgot, ran back out to the truck and backed it out of the driveway. Only problem was that I forgot to shut the door which hit my gate and bent the door back to the fender. Had to call my boss and give him the bad news. It took years for my boss to stop giving me a hard time. -
About 10 years ago I had a Jeep CJ5 with a 304 V8 and a sloppy shifting four speed. I had just changed the carb to an electric choke Edelbrock. On a cold winter morning I went outside to warm up the jeep. I checked the shifter to make sure it was in neutral. I should have checked better. The new electric choke worked great, reved the engine to about 2000 rpm. The jeep was in first gear. I held on to the roll bar and went for a ride down the driveway thru my rought iron fence. I finally stopped when the jeep ran into the back of my new Dodge Ram Quadcab truck I had just purchased. Never do that, my wife still reminds me. -
The 326 also had the same block. The head bolt pattern changed between 64 and 65.
