Hi I am hoping some of you guys can give me some direction with the problem i am having. I have installed a ms2 v3.0 board on my l28et swapped 280z I had the car running fine on the stock ecu and harness with a z31 coil and prw-2 transistor module. I built the harness using the diyautotune harness all of the sensors are working and rpm signal injectors are firing I can smell fuel when I crank the engine. I did buy the ecu second hand the mods that it has are a map daddy, boost control, and pwm idle control. I am using the 83 distributor with the optical sensor and have it configured the way it's on the how to megasquirt your l28et in the diyautotune site. I have attached a copy of my .msq file and some pictures of my ecu please let me know what else I could test and if you see anything off in my software or hardware that might be causing it not to fire. Thanks
l28etnospark.msq
