cuzak901
About cuzak901
- Birthday 09/01/1987
Gender
Not Telling
Location
San Jose, Ca.
Recent Profile Visitors
cuzak901's Achievements
I just replaced the brake booster on my 240z and now I have like zero pedal feedback. There is very little resistance at the pedal. The car stops, but I don't actually feel the car slowing until I have almost pushed the pedal all the way down. Then it starts slowing fast, but still no pedal feedback. I can't do a gradual Slow anymore. I was driving the car for a two weeks with the broken booster and it was hard to stop but I could feel the force of the pedal pushing back as I was slowing down. Also if i push the pedal all the way, I can't engage the brakes to there max. Like I can't lock the wheels if I wanted. Only change was the brake booster.
Is there a way you can tell what clutch I have from the pics I put there. Because the contact pad on the clutch is bigger then the one I purchased. Also it has 9 bolts and the one I got had 6 mounting holes. Also i'll check the drive shaft play in the morning. Is it possible that the clutch I kept is to thick and is keeping the throwout bearing in contact with the clutch plate. Could that cause the noise. Also on deceleration I noticed that when I keep the car in gear(especially the early gears) I get a scrubbing/rubbing sound. Not really grinding more scrubbing.
if the car didnt used to make the sound till after the swap and i reused the trans mount. wouldnt that make it ok? also were is the outputshaft bushing. is it somthing i can look at without opening the transmission
Hey haven't posted in a while but i read often. I did a 280yz project 3years ago and its great. Now to the point. I just removed my 4 speed transmission that was bolted to an N42 block L28 and put in a 5 speed from a pick'n'pull, 1980 280xz I believe, now I used the clutch that was already on the car because it was still good and had a bigger contact surface then the one I purchased new.(plus the clutch wasn't complete and the new bearings weren't in the clutch kit) So now as I accelerate with the new transmission, I get a vibrating ringing sound and can't pin it down.only on acceleration,if i start slowing it goes away. OK so I used the 240 transmission-mount, drive shaft, the hydrolic clutch piston thing that's attached to the transmission(11/16), the black clutch fork that its connected to, throw-out bearing. Basically all the clutch parts transferred them to the 5 speed. left the 5 speed shifter. Also I forgot to get the speedometer plastic gear and I had to use the 4 speed one(yellow for sure 17 pins i think)The speedometer doesn't work now but the tachometer does. Also down shifting or getting back into gear from neutral while at speed is not so smooth. these are the problems. now for the question. what is this transmission. I thought all 4 speed transmissions were 2 piece with the bell housing permanently attached. when removed it it was clearly a 3 piece transmission. also the shifter looks unique to me. also this is the clutch i kept in with the 5 speed junkyard transmission. Pretty much any info would be nice on the transmission but figuring out the ringing sound is more important. i found some info on the transmission after going here http://zhome.com/ZCMnL/tech/AandBtranny.htm
what lug nuts r u using with the ARP 100-7708 long wheel studs
no problem I got them at what i think is a deal but they are 295/50/R15 and the brand is Legend GT and tire is called Eldorado, there not race tires but for daily driving all weather hope that answeres ?
on the ZX the front end is from kit called drift. the back skirt dont know bit saw it on the back of a supra last generation, the side skirts where actually from 2 different kits, cut in half and made to fit. we didnt do the work. He got the car that way. I think u can find all the parts u need in the Dec 2005 issue if import tuner magazine and the drive train for now will remain a stock L28 untill i get the guts to put in a RB25 or mabey AWD RB26. If i do put the 26 i will try to keep the AWD. The primer is PCL polyprimer high preformance hi-build Black Polyester primer. Im prity sure its PCL but the Primer ran down the lable and i can only c the PC. It needs no thining and filled up all my scratches and minor dents. I think afterwards i have to use an epoxy primer to seal it all up.
Ive been posting about my car but i havent realy shown my entiar car yet so heer it is for your eyes only. PS. my brothers 280ZX is in it too.
My brother showed me the lights off a 3rd generation RX-7 that would probably fit into the fender see pic the other lights are the PIAA P-3000 amature Photoshop action goin on:ugg: Sliding u got to do somthing about those pics there bigger than my screen
ok thanks ill give it another coat this weekend
