The Camaro rad. from 1984 to 86, with standard cooling, the heavy duty rad is too wide to fit. The one you want is about 25 inches wide, aluminum with plastic side tanks. Get the upper fan shroud and rubber mounts (4, 2 upper 2 lower). The fan shroud holds the upper rubber mounts and the top of the rad in the car, if you have time it can be adapted to work in the Z car and you can figure out lower rad mounts mounted on the frame rails, you need to mount the rad with the 4 rubber mounts or it will shake apart if mounted solid in the car. With the engine in the set back position I run a stock camaro engine driven declutching fan blade and have no cooling problems at all, this is a street car, I'd go with the elect. fan for a drag car. Hope this helps.
