Recently bought a 1986 Chevy Truck. The Engine Smoked Badly. When i took it apart, the Pistons were wrong. I could move em around in the Cylinders. Not Good. A Buddy of mine Suggested that since i had the Engine down and was gonna rebuild it anyhow, i should make it a Toy. I agreed. I've Purchased Most of the Performance Parts that i'm going to use and some are Stock. I Made the Mistake of Jumping blindly into it. After doing some Research, i've found that building a Performance Engine means so much more than buying alot of Cool parts and slapping it together. The More i read, The more i'm concerned about things like My Valves hitting my Pistons and Not being able to use Gas From a Normal Gas Station. Perhaps i can give you a list of the Parts that i have and you can tell me if this thing will work.
Block: 1972 Small Block 350 Chevy with a 4 Bolt Main. Cylinders are .060
Crank: NEW Nodular Steel Counterweighted. Stock Stroke of 3.48
Rods: Stock, Stock, Stock
Pistons: Speed Pro STL-H345NP Hypereutectic Aluminum
Flat Top
Compression Distance 1.560 in
Piston Head Volume +5.00cc
Four Valve Releifs
Pin Diameter .927 in
Camshaft: Lunati
Duration: 284IN/284EX (218IN/218EX at .050 Tappet Lift)
Lift: 458IN/458EX (At 1.500 Rocker Ratio)
Lobe Separation: 110
Heads: Stock 882s
Combustion Chambers: 76cc
Decked .052
Intake Valves 1.94
Springs: Heavy Duty Rated for .600 Lift
Rockers: 1.6 Ratio (New Valve Lift is .488?)
Intake Manifold: Edelbrock Performer (I think)
Carb: Edelbrock Performer 600 cfm Manual Choke.
Exhaust: Nice Set of Headers.
I'm Currently Not concerned with the Drive Train Gear Ratio. I just want to know if this Engine will Go together and Run well. My Transmission is a 400 Turbo with a Shift Kit and i THINK i have 3.53 Gears.
