God no, I've had enough problems with ACT clutches in several Evo's I've worked on to make me stay away for life
South Bend Clutch
http://www.dxdracingclutches.com/html/skyline.html
There's several options but the extreme duty 6-puck is sprung and rated for 800+ ft/lb's of torque (in a skyline weight chassis) Since you have a multi-disc you'd need to find an RB flywheel. The pedal stiffness is not bad at all. I have driven ACT, RPS, etc that are way worse.
What trans are you running? I also did this upgrade and it made the pedal feel significantly better. This fork is much less prone to flex with higher clamp load pressure plates.....
http://www.zspeedperformance.com/Nissan-90-96-300zx-Heavy-Duty-Clutch-Fork-Upgrade-Kit-cd000kit.htm
It says' for 300ZX but it works just fine with my RB25 bell housing.
